Beware: Moog Strut mounts
Well...I'm sure that I had read the warnings from others regarding Moog upper strut mounts, but it didn't sink in...until now. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I spent today replacing my upper and lower balljoints, upper and lower control arm bushings, and shocks/springs. While installing the pass front shock/spring (of course this was the last major piece during re-assembly) I ran into the problem of the strut mount not aligning with the bolt holes. I took some time with a straight punch and was able to get the bolts started, but then came the new issue.
THE CAPTIVE NUT IN THE STRUT MOUNT BROKE LOOSE!!!
The last bolt was halfway in when the nut started spinning, we tried to continue, but nothing would hold the round nut. I was finally able get the bolt back out, and now I have to order a new mount.
Does anybody see a reason why I can't run 2 different brands of mounts?
(I really don't want to tear the driver's side apart again if I don't have to)
Any recommendations on what brand to order that will line up properly the first time?
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Its Ok to have two different mounts on a daily driver. I would not do it on a car set up for competion. Get the OE mount from GM. They are the only mounts that truely fit, and few people if any, have complained about.
Thanks for the reply. I called the local dealership. They quoted $200 for the mount, and none in the nearest wharehouse. I checked the gmpartsdirect website and they were about 30% cheaper, but again, waiting for shipping. The car is on a hoist right now on base, so I am paying to rent the space. I can either temp install the current one, put it all together and wait for the part, or try another aftermarket one and possibly modify the mount holes.
Any suggestions?
Any suggestions?
This is what I ended up doing. I tried MOOG, TRW, and Monroe mounts, and all had the same problem. A minute with a die grinder on one hole made it fit just fine.
