Is this fixable???...
Old Jan 11, 2010 | 07:18 PM
F-BodyMind's Avatar
Unhappy Is this fixable???...
My friend sold me a pair of bilsteins that came off his firehawk, he had a mechanic install lowering springs and well the mechanic screwed up and sliced the top of the strut when removing the nut. He gave them to me dirt cheap and im wondering if they can be repaired. Its a real shame since they had REALLY low miles.
Attached Thumbnails Is this fixable???...-1218091704.jpg   Is this fixable???...-1218091705.jpg   Is this fixable???...-1218091708.jpg
Old Jan 11, 2010 | 07:33 PM
ssam98's Avatar
you can try by chasing it with a new nut.
Old Jan 11, 2010 | 07:54 PM
therealcreeper's Avatar
bilstein does do repairs, so if chasing it doesn't work and it doesn't stick up far enough to just chop that part off you can send it out
Old Jan 12, 2010 | 06:00 AM
pjb's Avatar
pjb
you might have better luck with a rethreading tool, rather then just trying to run a nut down on it, but either might work. it should be OK as long as you get the nut down below the messed up part. On the other hand, I wouldn't be to anxious to buy used shocks.
Old Jan 12, 2010 | 10:51 AM
Sam Strano's Avatar
LS1TECH Sponsor
If you use a die on it you should be ok as the nut actually sits/holds further down the threads. You need to definitely use a thread die on it then be careful when tightening the nut down.
__________________
Old Jan 14, 2010 | 05:59 AM
BTL FED's Avatar
What Sam said
Old Jan 14, 2010 | 01:07 PM
one of my shocks had a little damage to the thread and i didn't have a die handy, so i used the edge of a file to clean up the damaged threads a bit and then just chased it with a new nut
if you have the tool that'd be the way to go though
Old Jan 14, 2010 | 01:46 PM
ae13291's Avatar
clean it up with a threading tool
