Brake setup on my 2002 Z28
1 Post
i just wanted to slap on the rotors for now, i know about the brackets, i was working on using brembo calipers to fit under the 17's but i lost interest, (unless i find some radial calipers or ones off a mitsubishi evo) i was going to fabricate some brackets with my dad so we can fit on the c5 rotors and bolt up the f body calipers, i dident want to waste my money on another set of floating 2 piston calipers from a c5
if you want C5s in the front, then do it right or not at all. im no fan of everyone else doing it halfassed, and just using the rotors or just the calipers, or whatever. its called a C5 conversion for a reason.....all the parts are meant to work together. in addition to the larger C5 rotor, you get a bigger pad with the entire C5 setup, thereby increasing your brake performance in that regard.
if all you do is drag race, you dont need ANYTHING other then fresh stock parts. especially in an 1/8 mile, there is no way youll be going fast enough to worry about stopping. if you are, your car should be fully caged and have a parachute anyway. use HPS pads, new stock replacement rotors, flush fluid, and if anything braided lines. thats all you need for drag racing, or any street driving.
thank you for the response, seems like i will go the route of putting on the c5 rotors and maybe down the line upgrade to some c5 calipers or brembo's.
i also have a question unrelated to rotors, would a brake pad dry out or possibly be bad if its older then for instance 5 years?
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Yeah I've heard a bit about the C5 conversion, and it just doesn't seem like it's worth doing. Call me ignorant, but I don't really see the benefit of having C5 rotors unless you're trying to do some kind of insane braking stunt. Yeah my stock rotors and pads didn't really give me any problems when I ran it down the eighth it just left a little more to be desired you know? So the ATE rotors with the HPS pads are the way to go outside of a C5 conversion? What about the type of rotor? Would you recommend the slotted ones over the blanks? I like the way the cross drilled ones look, but like I said, I've heard negative things about the structural integrity.
Are we fine with using our stock calipers when doing the c5 conversion? I know the main benefit is the larger c5 pads and the 12.8inch rotors and based on what I read, the calipers are well matches besides the fact that the c5 units are produced using a different technique.
1 Post
This concern is blown way out of proportion. If you plan on doing HPDE events or anything with sustained high speeds they are not the best choice. If your car is primarily street driven with occasional auto-x or eighth mile runs they will work fine and provide added airflow which will keep them cooler. Not all cross-drilled rotors are engineered the same way. Drilling too close to the outside edge, over drilling or drilling small holes will all create more stress risers. All Powerstop drilled rotors come with a one year manufacturer warranty against cracking and three years if used with Powerstop pads. BTW any rotor can crack if abused. I don't care what blanks you have, let me loose on road america for an afternoon and your rotors will be ready for the scrap bin.
