Has anyone installed budzter coil spring height adjusters
WARNING: BAD TRADER STATUS
Has anyone installed budzter coil spring ride height adjusters? If so how hard was it to grind the lip off your differential to bolt the budzter's on? Has anyone used the spacers so they didnt have to grind the lip off? If so how much height did this add to the rear of the ls1?
No, but do you have a link to the manufacturer for reference?
Also, usually anytime you have to "mod" a new item, it's always good to check with them to see if you got the correct part!
