Corvette C4 or C5 Calipers which to run?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Well this is my first question. I recently bought a 01 bird that has some race miles on it.
The previous owner converted the front brakes to vette ones. It has C-5 rotors and C-4 Calipers. Can I convert to C-5 calipers to keep everything the same or should I just keep this setup. Thanks John
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Depending on how the caliper has been mounted you may be able to upgrade to the C5 Caliper. I did a C5 conversion on my 2000 SS.
See this post: https://ls1tech.com/forums/suspension-brakes/113284-c5-13-brake-upgrade-my-2000-ss-pics.html
Well I did a little digging and found that I have my info messed up, it has C-5 calipers and c-4 rotor. So I should change the post around. Z-28 thanks for the info, so can I upgrade to c-5 rotors or just leave them alone?. Thanks for all the help. John
