Impala 1970 - Drum to disc brake conversion kit - need help
Hi,
I have an Impala Convertible 1970 350 cui.
I am looking for a Drum to disc brake conversion kit for the front breaks.
Unfortunately I am not able to find one for this car.
e.g. I would like to buy this one:
http://www.ssbrakes.com/commerce/det....cfm?nPID=8309
But it is not compatible with my car according to SSBC tech man, and they do not offer one for a 70 Impala.
I do not understand it, because you can use it for e.g. 1964-1972 Chevrolet Chevelle or 1964-1972 Chevrolet El Camino.
Who can help me? What does fit for my car and where can I buy it?
Thanks
Thanks
Thanks. Good hint.
Does someone know something about mpbreaks.com. Are they ok?
http://www.mpbrakes.com/products/pro...product_id=391
You should be able to use the 73-77 gm a body spindles, they are the same for 2nd gen f-body and novas too. The spindles are a common upgrade for the 72 and older chevelle because they are taller it will give you better handling. You will need a new master cylinder for disc. This is a straight forward swap.
I had a bad experience with master power and won't use them again.
