what is too low
Old 02-14-2010, 02:12 AM
z28bluess's Avatar
Default what is too low
i am about to do a true dual. how much is too low? i dont want to scratch my new exhaust.
Old 02-14-2010, 04:12 PM
z28bluess's Avatar
still no help? anything would help
Old 02-14-2010, 05:00 PM
camarozl1's Avatar
http://www.ls1tech.com/forums/genera...ill-clear.html
Old 02-14-2010, 05:33 PM
z28bluess's Avatar
ok thanks. not getting tsp one. having a shop custom do them but sure eibach should work then.
Old 02-14-2010, 05:34 PM
99Bluz28's Avatar
Lightbulb
IMO, do either the true dual exhaust or lower the car, not both.
Old 02-14-2010, 06:10 PM
z28bluess's Avatar
i really want to try both. exhaust is more important.
Old 02-14-2010, 09:18 PM
StealthFormula's Avatar
My car is lowered 1.25" with Strano springs and I have 2.5" TD's. I have never scraped any part of the exhaust except for the turndowns once when I was flying down the road and nailed a bump. I wouldn't worry about it with the Eibach Pro-Kit. Just take it easy over speed bumps and such. I'm actually going to lower the car more when I get adjustable drag coilovers, so yes you can do both and be ok. BTW, my TD's were fabbed by a good shop with alot of experience doing TD's on 4th gens which helps with ground clearance over some random place taking a stab at it, I've seen some **** jobs that simply hang ridiculously too low.
Old 02-14-2010, 10:09 PM
z28bluess's Avatar
this guy that i am going to has a firehawk and one of the founders of a local car club so i hope he does good work. i have heard lots of great things.
Old 02-15-2010, 01:27 PM
bigj2717's Avatar
If youre going to do both lower it first and then setup the exhaust at ride height so you can tuck it up as much as you can
Old 02-15-2010, 01:40 PM
ls6firebird's Avatar
mine's lowered 2 inches. i dont have true duals, but i dont think true duals can be any lower than my y pipe is....its BAD. if im not careful it'll scrape real easily. but ive only done it a couple times and learned real quick and have been fine since
Old 02-15-2010, 01:43 PM
KevinR's Avatar
Good point. I lowered mine first then did the exhaust. I still scrape every once in a while, but I just try to avoid the big bumps.
Old 02-19-2010, 06:16 AM
Trunion King
bene's Avatar
I have both.
Old 02-19-2010, 06:47 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Anything can be done with a little custom fabrication, and that includes working on the floor pan. A hammer and doly on the floor pan can create enough space for a true dual setup and a lowered stance. I would so love to a see someone like Chip Foose make an ultimate 4th gen Camaro or Firebird. Just imagine what he could do.
Quick Reply: what is too low
