rear springs for moser height increase
ill will be swapping my moser into the ta from my camaro soon and need to know if the hotchkis rear springs are the best choice to level the car out. ive read the moser adds 1" in height. ive also read that the hotchkis springs can drop more than an inch. i will be leaving in the spring spacers and adding hd bilsteins at the same time. i dont want to drop too low since im adding 315 tires in the back, and i want the car level or higher in back a little. i was thinkin about the bmr springs but read they are stiffer than the hotchkis and they drop lower than a inch also. i searched alot but all the threads dealt with all 4 springs. kev
When I first intalled my Moser, the rear of the car was up too high. I then installed BMR rear springs with my Moser. I think the Moser adds 3/4" while the rear springs dropped it 1". The rear is sitting a tad lower than the stock front but I'll be doing the front springs soon so it should give it a raked look. Keep the rubber isololators in and you should be fine. I'm pretty sure BMR doesn't drop more than an inch. The ride is nice too, not too harsh like some others. I have 315's in back and after pounding the inner fender and rolling the fender lip, they never make contact.
thanks for the info shawn. i think i read some of your other posts on this subject. i was hoping to avoid rolling the fenders if i get the nitto 315s DRs, but i plan on pounding the wells. maybe i could take the 1/2" isolaters out and forget about springs and deal with the 1/4 inch increase. i never noticed any increase in height on the camaro, but i never checked either, and i did remove the isolaters. i defintly dont want to sit lower in the rear. did you remove your isolaters? my mods will be nearly identical to yours very soon.
i just found that slp springs drop the back 3/4 of an inch, that would be perfect. as much as i hate to give them any buisness. anybody like slp springs?
LSX Mechanic
Another way to lower the rear back down after the Moser and without having to buy springs is taking out the spring purch on top of the rear springs. It's free, and easy. Pop the springs out, and you'll see the rubber purch they sit on. Leave it out, and run a piece of heater hose all down the first 2-3 coils of the spring so it'll provide some cushion and prevent noise. This will lower your rear ~.75-1 inch.
Josh
Josh
well if it lowers it that much ill be happy, i wont need springs. i removed my isolaters and used hose when i put the moser in the z last year, thats why i didnt notice any height increase i guess. ill try it without new springs at first and see what happens. i want to avoid lowering springs if possible to have traction with upcoming mods including a yank converter. kev
