street strip setup?
The norm for a street strip setup is Strange/QA1/AFCO front shocks usually double adj(DA) but people have turned in impressive times with Single Adj.(SA) Then for the rear the same shock as the front but depending on what trans you are running you can go with a DA or SA Here's a little tip, if it's a six speed car a DA setup is the way to go. I have DA on my auto up front and SA out back.
Springs for the front are based on weight normally. You'll be fine with the stock rear springs.
This setup is far more optimal for strip performance but it's not bad on the street. The days of high speed turns will be gone though.
~Jim~
I noticed that you are looking into a different spring and shock combination. And like mentioned above and to help with maximum weight transfer to help put that 600 HP to the ground. I would suggest going with a front coil over setup. With a 300lb spring for both street and strip. And seeing how you don't want to slam it. They will allow you to adjust the ride height (as long as you get the thrush bearings and spanner wrench for easy adjustments). And for the rear stay with the factory rear spring. And eliminate the spring isolators and slide a piece of heater hose over the spring. And to help keep the weight transferred so its doesn't unload so fast. I would suggest going with a adjustable rear shock. Below is a link to show you what all UMI Performance has to offer!
http://www.umiperformance.com/catalo...7hp3l5katkrpf2
If you have any other questions feel free to ask! And I will be more than glad to help.
Thanks
Brad
^^ this is to work with LT's but if you have kooks LT's it's a diff kit.
With that type of HP I would suggest going with a tunnel mounted torque arm, with a drive shaft loop for at the track. Now depending on what your exhaust combination your running depends on what tunnel mounted arm you choose. Below is a few links to show each tunnel mounted version I am explaining.
http://www.umiperformance.com/catalo...6t2g3ooet91a44
Thanks
Brad
I'd get the tranny relo brackets
X2 on that. I was in this boat for about 3 months. I wanted to have an 11 second motor car and then be able to take corners at double the suggested speed. That just doesnt happen. I finally decided that geting it to hook up was what I wanted. I bought a new rear, drag wheels, 28in slicks and saving for Afcos or Strange..
Most will say for a 6 speed your going to want a D/A shock (double adjustable) in the rear. For the money Strange is the way to go. Id stay away from QA1s. Some say they are awsome and dont leak anymore, who knows if thats fixed or not, Im not going to chance that with my money. But Strange and Afco seem to be what a lot of guys run. The reason for a D/A shock is so can keep the rear tires planted and from "unloading". A Bias Ply (ET Drag or Hooser QTP) something around that will also help the tires from unloading. A Radial once it starts to spin its hard for it to recover, so therefor you spin more. Iv seen plenty of guys go with a single adjustment on the rear with a six speed and do OK. My self as much as I race (50 passes a year) I will save a few dollars and get singles for the rear. Unless you race every weekend and need those extra .10s...I wouldnt spend the money. They have too many adjustments and more than likely never get to use a 1/4 of them..
For handling just run sticky (at least 275) tires all around, with konis and strano bars. Then at the track disconnect the front bar, and run the konis on full soft in the front with slicks and skinnies.
https://ls1tech.com/forums/suspensio...-60-konis.html
