Rear panhard bolts not fitting into LG adj bar bushings???
did you adjust the bar to the factory length before installing it?... if it's too long or too short then it may not be aligning with the mounting holes... your rearend could have shifted a little bit when you removed the factory bar so you might have to push and pull on it to get the holes to line up... when i took my factory bar off my rear shifted over to the driver side quite a bit and i had to push on it like a son of a bitch to get it back in place so the bolts lined up... i could have used an extra hand but i managed alright haha
No the issue wasn't there, each side fit fine in relation to the brackets. The fitment issue was getting the bolts to slide through the rod end bushings on the adj side (drivers side). I ended up having to drill out the diameter of them big enough for the bolt to slide inside.
