Anyone running SLP Bilisten/BMR spring combo?
Just wondering if anyone's running the SLP Bilisten/BMR spring combo and I'd like to know what they think about it.
Thanks!
Thanks!
SLP spring/shock combo
I'm running the SLP spring/shock combo. I like it for the most part. Didn't really lowering the car much. Actually thinking about switching to the QA1's for some adjustability. For the most part its a good package. I know its not what your looking for but gives u an option
^^^ what kind of adjustment are you looking for out of the qa1's?
and OP, you could also ask for peoples' input on SLP bilstein/Strano setups since they're almost identical in terms of rate and drop
I looking for ride height adjustment and dampening too. What other options are there for ride height adjustment? A buddy of mine is changing out his QA1's for an Air Ride system, that's Y i was thinking might as well try them out.
if you're looking for damping of any kind look away from Qa1's. they're not even pressurized shocks i don't think. if you want height adjustment there's the ground control and global west coil sleeve kits, edelbrock IAS coilover kit, and KW V3's.
I have the ground control setup with Koni SA's and it's pretty sweet.
I'm running that combo only had the car for a couple of days and it's down right now (tranny related). It's a good combo to me and I like the ride quality and the car feels more stiff and more respondable. I have Kook's LT, Catted 2.5" X pipe and the clearance is pretty good. If I can find the cord to tho the camaro I'll post up the pictures and have the coke can for clearance. The car has a very nice stance with out scraping and bottoming out on everything which is great.
