droping the car! few questions!
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
igth guys i just got a set of Eibach sportline springs and a set of SLP Blisten shocks, i'm goign to be puttin these in very soon and i heard some of my freinds talking and i was just wondering, to do this am i goign to need a special spring compressor to compress the spring on the car or will i be able to pull the hole thing out and use the bench spring compressor. that is my only concern w/ the front i figure the the rear should be a peice of cake! any pointers would be great thank you guys!
Not sure about that question, but did you already get an adj. PHB and LCA brackets. You need these due to the new lower ride height son your car. BMR has both and the LCA brackets are bolt on or weld on.
