What suspension???
Basic set up is of car is so maybey you can help me from here... I will be leaving on a th350 t-braked, possibly on the kit out of the whole....
Also if anybody has any setups for sale lmk!
thanks chris!
I noticed that you are looking for some suspension suggestions to allow you to allow you to come off of the line harder. And like 1LEJohn mentioned if its a street car then I would suggest going with at least a set of single adjustable components in the rear end. Having a poly bushings on the chassis side will still allow for a great ride quality while the rod end on the rear end will hold up better then a poly under hard launches. And to maintain a great ride quality on the street and still allow the suspension to be bullet proof. I would suggest going with a full length arm with a relocation cross member to get the arm off of the transmission to eliminate any issues with possibly breaking the tail-shaft.
But if you are looking for maximum weight transfer then I would suggest going with a tunnel mounted version. They not only transfer weight faster due to the shorter arm. If you tie them into your suspension with a set of 3 pointers then you pretty much have a indestructible suspension that is working as one whole unit. Below is a link to show you what all UMI Performance has too offer!
http://www.umiperformance.com/catalo...j1rt5sc8s114m5
If you have any other questions feel free to ask.
Thanks Again
Brad
