Rear End Install !NEEDHELPFAST!
So here is a list of all the stuff I've installed.
-Moser 12bolt
-UMI Adj. Torque with Relocation Bracket
-UMI Adj. LCA's with Relocation Bracket
-UMI Adj. Panhard Bar
-Koni 4/3 shocks *only the rears installed at this time* (set to the softest setting)
-HeaterHose Mod done to factory 2001 WS6 springs
So here is the issue, I have everything in place set to factory settings. All the mounting bolts are loose because I want to load the suspension before tightening as the instructions call for. Well I let the rear end hang free with the car up on stands. I place a jack under the third member of the rear and jack. I only get about 1/2" to 1" MAX of travel before the whole car starts lifting. Now I'm thinking this might be normal since everything is newly installed maybe not set just right and things are a bit stiffer but with the full weight of the car on the rear end I'll test fit my tire and I have about twice as much wheel gap as I had before. This makes me think something is way wrong.
Any help is appreciated guys. I could really use some input.
A few things I've though of, no nothing is binding between the rear and the car. No I'm pretty sure its not the Koni's because I have wiggle them very easily by hand. Don't think its the LCA because I can still spin the mounting bolts with my fingers.
Panhard bar, Torque Arm are the culpret(s) ?
thanks guys!
