Reinstall Torque Arm bolts up instead of down???
Anyone done it? My buddy thinks it is OK, but I am a bit of the skeptic because I know my luck...put them in up instead of down, the lock nut lets loose and there goes the TA. If I go that route, should I just tack weld them to the mount? Have a Moser 9" and UMI TA.
I have been putting them in that way for a long time. Not saying its the correct way but I have not had one issue. I also am running a Moser 9 inch rear. I use anti-seize on the threads and a braker bar to get them tight. I check them fairly often but have yet had a bolt/nut come loose. If a bolt were to come loose it should be easy to feel due to the banging and noise it would cause, so I would think one could catch the loose nut well before the bolt fell out of the torque arm.
We HIGHLY recommend to run the bolts down. Like you mentioned, if the nut comes off and bolt will fall right out. If those bolts come loose it can cause damage to aftermarket torque arms and other things such as the drive shaft. Install the bolts from the top down then tack weld on the nuts, the correct way and with extra insurance
Ryan
Ryan
Kleeborp the Moderator™
I've only ever installed them with the threads facing down. I've never had a reason to install them any other way - I'm assuming this change in direction would be for ease of install?
Can the bolts really be that hard to install down? I don't recall having any trouble at all installing my torque arm. Well, let me correct that, I had a bitch of a time installing the poly bushing into the factory clamshell front mount, but maybe that made the rear bolts seem comparatively easier and they were a bit of a pain as well.
I have one up and one down the closest to motor has nut on top, I have stock torque arm, for some reason such a pita to put that one down, could never get angle right due to clearence issues....maybe the arm just warped lmao
One problem: an incorrectly tightened fastener has a much greater chance that it will fail. Fail in this case = SNAP. Granted, that would be the same no matter which way the bolt was installed.
Call me crazy, but I know that a torque arm failure will most likely result in severe damage to vehicle, and possibly injury or death to driver and others.
The bolts probably wouldn't fall out because clearances are tight around there, but why not just be on the safer side?
Bolts are easierto get to if you have the suspension unloaded and the proper tools.
Clearance the tunnel so you can get it right.
I don't think you need to "clearance" the tunnel, just let the rear hang....
