Panhard bar clunking
Old Jan 15, 2004 | 05:04 PM
SSalvage's Avatar
Default Panhard bar clunking
I have a bmr panhard bar and a spintech catback on my car, i also have 18x9.5 wheels in the back with bmr lca's and the weld-in relocation brackets. When my car is on the freeway the rear right side makes a clunking sound when i go over small bumps in the road. I looked under the car and whats happening is where the exhaust goes over the axle, it is hitting a metal piece on top of the pan bar. The exhaust tube has a good sized dent in it. Has anyone heard of this or know how to fix it.
Thanks
Old Jan 15, 2004 | 06:08 PM
Hambone 7's Avatar
probably just because you have aftermarket parts which are designed to be put on a stock car, not to be used with each other. you'll prolly have to cut or customize something.
Old Jan 15, 2004 | 06:33 PM
jimmyblue's Avatar
Moderator
This is one of several close passes on the exhaust. You can
try to rehang it or you can try banging in the spot where
it's scraped, a little more with a heavy hammer (this won't
hurt exhaust flow significantly but will maybe clearance it
enough to not bang).
Old Jan 17, 2004 | 12:12 PM
Creed's Avatar
If all else fails just take it to a muffler/exhaust shop and they can get you fixed up right and probably for pretty cheap too.
