"knock" type sound..
Old Jun 23, 2010 | 04:23 PM
Badguy7's Avatar
Default "knock" type sound..
Let me put it this way,
I back out of the drive-way, parking lot or wherever i am. I put it in drive, and start going. The 1st time i have to hit my brakes, i get that knock type sound. Its like if something popped into place in a way and it wont make that sound ever again untill i stop the car. No matter how many times ive come up to stop signs, red lights & anything that forces me to apply the brakes.
Once i stop the car at the store or home, then i back out again later on. The 1st time i have to brake, it makes the noise.
This has all been happing, since i installed the strano springs & koni shocks.
Anyone know what the problem is, or could be? It's just 1 solid knock, i feel as if its coming from the driver side, since i easily hear it but will check both sides regardless.
Old Jun 24, 2010 | 02:12 AM
Carter Hays's Avatar
Are the front shock nuts torqued down? I have seen so may that are not. Just a thought.
Old Jun 24, 2010 | 07:22 AM
UMI Sales's Avatar
Hello
Did you put the spring isolators back in? I am sure the springs are seated properly. Like suggested above! I would make sure all of the hardware is tightened to specs. If you have any other questions feel free to ask.
Thanks
Brad
