Rear sway bar for drag racing!
Old 01-19-2004, 10:59 AM
bluestreak98's Avatar
Default Rear sway bar for drag racing!
Ok, i did the search and pretty much all i got was what sway bar to use in the twisties...
Well, what about for the drag racers?
Would a 21mm rear 1LE sway bar work just as well as the BMR 21mm? Can anyone help me out on this?
Thanks,
D
Old 01-19-2004, 11:49 AM
1madss's Avatar
You might consider just going with an airbag in the right rear spring. This worked wonders for me and does not effect your daily driving. It's much cheaper also
Old 01-19-2004, 01:02 PM
I have one
Old 01-21-2004, 06:00 PM
BISHOP's Avatar
BMR Extreme Duty sway bar here and a pair of bags.
Old 01-24-2004, 07:50 PM
Neo7600's Avatar
Thanks,
D
For strictly drag racing, the BMR extreme duty sway bar is a good way to go. It is a 32 mm solid bar, comes with 5/8" chrome-moly rod ends, and heavy-duty 3/16" mount plates. You can order it for 2.5" to 3.25" axle tubes, and will work with any rearend, stock or aftermarket.
Old 01-24-2004, 07:52 PM
Nice4thgenZ's Avatar
i've heard the BMR extreme duty sway bar is the only way to go with rear bars
Quick Reply: Rear sway bar for drag racing!
