Left side of car jacked up??
My car is lowered with factory shocks, LG Motorsports adjustable LCA's, LGM adjustable PHR and BMR LCA relocation brackets. My problem is the left side of my car looks like it is jacked up in the rear. It has about 4 inches of fendergap and the car is tiliting to the right. The right side of the car has only one inch of fendergap and the tire is kind of tucked in the fenderwell from where the car is tilting. What the ell is causing this? Is the spring binded up or something? It drives fine and makes no mysterious noises...?
If you have taking out the rear springs from the perch you may have put it in wrong. You may have to spin the shock around to get the ride height back to normal. I took the rear out of my old TA and it took me a while to get it back to normal. Look at wear the end of the spring is on the other side and try to match it up. Hope this helps.
