greasing lca's
greasing lca's
I just bought a set of umi rear lower control arm's and i was wondering if they come greased from the factory?I'm going to install them today.Where do you buy this marine grease they describe?Any parts store or do you have to go to a marine store?
Thanks for choosing UMI Performance for your suspension needs. No the control arms that we offer do not come pre greased. And when you do grease the control arms I would suggest only using 1.5-2 pumps of grease per grease fitting. And yes you can pick a marine based grease at your local auto parts store. We suggest the type of grease due to the fact that it holds up to water and heat better then standard grease.
If you have any other questions feel free to ask.
Thanks
Brad
