LG Brake Bracket Bolt Torque?
As the tongue twisting title suggests, what torque would you all recommend for the LG Motorsports C5 adapter bracket bolts (the ones that bolt the LG brackets to the spindle)?
I know the torque spec is 74 lb ft for the F-body abutment bracket bolts. It's around 125 lb ft for the Corvette bracket bolts (I think this is a 14 mm bolt though, as compared to the 12 mm for the F-body). Would something around the F-body spec of 74 lb ft be best? Not really sure here, just want to do what's best.
I would torque the bolt to it's assigned value for its given size unless it's a specialty bolt like a torque to yield etc.
The bolt does not know where it's at only that it requires a certain torque value to properly clamp.
