Goodridge brake lines with T/C
I'm not sure how much of a purpose they serve. My Goodridge lines came with new clips that had a slightly different design than the stock ones. You might check with Goodridge about having them send you some.
just make sure you don't over-tighten the banjo to caliper bolts, the caliper is aluminum so be careful. Also, spray all of the fittings and bolts with PB blaster, etc. a day or two before you start.
