Help with Strange Double Adjustable Shocks
Old Aug 10, 2010 | 11:26 PM
SS125's Avatar
Default Help with Strange Double Adjustable Shocks
I just put a pair of the Strange Double Adjustable shocks on the front and the Strange single adjustable shocks on the rear. I know the front shocks ***** are for compression and rebound. Which is which, how do I tell the difference. On the rear shocks, is that for compression only? Does anybody have a baseline that I should use to initially set the fronts and rears at? This car is primarilly a drag car, not a dd. Thanks
Old Aug 11, 2010 | 09:13 AM
BMR Tech's Avatar
Give me a call here at the office and I can go over some good baseline adjustments for you
Old Jul 8, 2012 | 09:00 PM
Blwn_by_Twins's Avatar
Bumping this b/c I'm in the same situation. I don't know what **** does what. D/A's in the front and S/A out back. Thanks
Old Jul 8, 2012 | 09:18 PM
djfury05's Avatar
On my dbl adj AFCOs the compression **** is on the bottom and rebound on the top. I am guessing its the same for Strange but not 100%.
Old Jul 9, 2012 | 08:11 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
The Strange shocks have both ***** at the bottom of the shock. The larger plastic **** with the ridges is the extension(rebound) adjustment, the round metal **** is the compression(bump) valve.
