Any tips for cross-threaded suspension bolts?
I've snapped off 2 sway bar bolts now, and just had to order new strut mounts since their nuts were perma-corroded (we twisted the inside of the DeCarbons into a corkscrew trying to get them off)... looks like whoever put my car together did so on a monday. Any tips for getting these off, or dealing with a cross threaded bolt, other than forcing it and then replacing the bolt/nut?
sway bar bolts should never be re-used anyway. theyre cheap enough to buy then entire package, with bolts and bushings, to not even worry about it. the old fashioned way of removing sway links was to put an air ratchet on it, and tighten it till it snapped.
you might as well replace all the hardware with new, quality pieces, if they didnt come with your new suspension. you can even try stainless hardware, or at the least use some neversieze, if you plan on taking it apart again.
