Rack & pinion issues
I tried a search & can't beleive I'm the only one who has a massive leak lol. I am on my 2nd rack & having the same problem. It constantly drips to the point where I have a new trail up & down my driveway everytime I take the car out. If I turn, there is a puddle, & if I jack the car up it will empty the entire system down my left hand tie rod & onto my brake rotor & wheel. Not wanting to replace with another POS unit so is there a good fix for this or a better aftermarket option? I was also looking to replace the pump with a PSC 1200 series pump to try to upgrade the whole system at the same time.
Any advise is appreciated.
If you got a re-man rack from Advance, Autozone, Pepboys, ect., then thats most likely the problem. They are junk.
how do you get the rack out, the bolts drop in from the top? im doing this right now as my cap was leaking pretty bad, ive got it all disconnected but dont know how to get the two long bolts out from the top
