Brake Bleeding question....
Old Sep 14, 2010 | 09:15 PM
Nastyc4's Avatar
Default Brake Bleeding question....
Looking to do this the classic way but every post I read up on has some interesting information. Does the stock brake system have the usual bleeder screws? I plan to have a friend pump while I release and pour in fluid to the master. Also I had a question about brake fluid.. it's been a while since I bled my vette or swapped fluid and can't remember whats on the bottle but i think it's dot 5 fluid from Wilwood that i have lots of. Dot 5 ok? I think it says compatible on the bottle not sure.
Old Sep 14, 2010 | 09:54 PM
99FormulaM6r's Avatar
It's just like bleeding any system, just be careful not to let the master get low and let air get into the ABS pump, then it becomes a PITA.
I'd recommend ATE Super Blue. Very recommended, not very expensive, and works great.
Old Sep 15, 2010 | 02:00 PM
mitchntx's Avatar
Regular bleed valves ... pump - hold - release fluid - seal system - repeat ...
DOT 5? NO! DOT 5.1? YES!
For track days and competiton type useage, ATE is great fluid. I personally hate to bleed brakes, though. What a freaking mess! And my experience with ATE SB, Motul 5.1 and RBF 600 and ProSpeed had me bleeding after a single track day using Motul 5.1 and RBF 600 and after a weekend with everything else.
So at $15 a bottle for ATE and 6 weekends a year, I was spending $80 a year on fluid.
I bit the bullet and bled Castrol SRF and I rarely bleed the brakes at all, now. I do open the bleeder valve as I'm compressing the pistons into the caliper during a pad change, but that is it.
In my race car, my system went solid with SRF in 2005. Never a system flush since. So in 4 years, I've spent $160 on fluid, never make a mess and concentrate my PMs on other areas.
At $80/litre, it seems expensive. But in the long run ...
