Eibach springs, now what?
hey guys i just wanted some input on what i should put on my car.
The previous owner says it has the eibach pro-kit and blue tokicos, but i think it sits alot lower more like a sportline but it has the black pro kit springs. I'll worry about and fix it. but for now i just wanted to know what i should put on the car to help traction.
Pan hard bar? what make?
Lower control arm? make?
Relocation brackets? make?
anything else. I just want the things that should be done with lowering....done.
Thanks for the help
i tried to attach two pics, but it didnt work
any suggestions help
Thanks for the help
PHB to center rear if not already on there..
See if you have wheelhop before you buy LCA/Relo...
My old 346 lowered on stranos cut 1.6x 60 ft. on stock LCA's. The good koni's were I am sure responsible. Good shocks can make up for a lot (even though they are not drag shocks...)
Hey fresno, just right down the road from me in madera!
UMI makes some really good suspension parts. Take a look at there LCA's w/roto-joints, and adjustable PHBs, and if your car has SLP rear bump stop spacers on it remove them for more (1/2") compression travel.
Go with relocation brackets, only if it's still an issue after the above is done.
