Ready to swap LS1 brakes to my 96 Z28?
I think I am ready to swap the LS1 front brake system on to my 96 Lt1 Z28 Camaro. From this picture, can you tell if I have everything I need to swap the front brake system over?
I have the stock LS1 brake lines coming out of the calipers....will those work? there is lots of information out there, I just cant get a clear answer of what I need.
thanks
thanks
![](http://i15.photobucket.com/albums/a360/nascarnate326/photo-6.jpg)
Looks good. Do you have banjo bolts and the copper sealing washers?
I've read that LT1 and LS1 lines were too short, but could be made to work by bending the brackets. I just went out and got some C5 lines and they worked nicely.
The banjo bolts connect the brake hose to the caliper. The copper washers seal this connection. They are a must.
You don't need to worry about the hard lines, just the hoses. You can probably get the LS1 hoses to work, but if you want to be safe you can pick up a longer set of C5 hoses. I posted a want ad on a corvette forum and got a used set for free.
