Strip suspension setup
Old Nov 18, 2010 | 01:26 PM
93camaro_zzz's Avatar
Default Strip suspension setup
Hey guys, Im looking in to getting my suspension done pretty soon, and have a couple of questions. First, I think I have decided on Strange Single adjustable for the rear on stock springs. But for the front, would it hurt me that much to just run a Bilstien, or some normal shock for the front? Or will I be seeing alot of benefit to a Strange single adjustable up front as well? Also will the stock spring for the front be effecting me that much as well? Thanks,
EDIT: Car is 2000 TransAm 6 speed
Old Nov 18, 2010 | 08:46 PM
Carl at CRP's Avatar
The Drag Racing bred Strange shocks will help Your car on the drag strip tremendously. Having the springs on the shocks where You can preload the spring is another distinct advantadge. If there is anyway possible, save up the money to buy the double adjustable rear shocks, it will serve You well!
Another advantadge is knowing how to use the adjustable shocks to make Your car perform, I will be glad to share this with You. Once You know how to use the shocks to make Your car work right You will be happy as ever, it is fun to twist a dial the correct way and see the short times drop!
Carl
Old Nov 19, 2010 | 10:51 AM
Thanks Carl. Yeah I cant wait to have those 1.5 or maybe even 1.4 60' times.
Old Nov 19, 2010 | 06:23 PM
sweet99ss's Avatar
quick times
Old Nov 19, 2010 | 08:34 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
If you could afford only one or the other (front or rear) that would be a hard decision since they are both beneficial at the drag strip. Ideally a double adjustable for the rear and single adjustable for the front would be great. You really need to be able to adjust the front shock rebound to control extension. This really helps to tune the cars weight transfer. If you can afford it, definitely do both...
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
