Shocks Replacement
If you're looking to get something a little bit higher grade, Koni's are really good, but cost about 2x as much as the Bilsteins. Koni's tho work well with lowering springs to if you ever decide to go that route, but they also work very well with stock springs too. It sounds like the Bilsteins would be fine for you however.
so İMHO , i think bilsteins are better , but if you have the money , koni's do live up to the hype..
Here's the Bilsteins I mentioned: http://www.stranoparts.com/partdetai...D=21&ModelID=8
Koni 4/3's: http://www.stranoparts.com/partdetai...D=21&ModelID=8
Koni 4/4's: http://www.stranoparts.com/partdetai...D=21&ModelID=8
The difference between the 4/4's and the 4/3's is that the 4/4's have an ON CAR adjustable rear and slightly different valving, while the 4/3's have OFF CAR adjustable rears and seem to be better when used with heavier rears (just from hearing some feedback on this forum). Either one will work great with a stock rear. BTW, if you didn't know, not only the rears but the front's are adjustable with the Koni yellows, while the Bilsteins are set from the factory with their valving and aren't adjustable.
So yeah, those are my suggestions, based on price. However, definitely give Sam Strano a call (the guy that owns and runs Stranoparts). He can take what you want from the car and help you pick what will be best for you, plus his prices are very competitive (or sometimes better) than other vendors and he won't talk you into stuff you don't need just to make a couple extra $$$$.
. All the Koni shocks for these cars are adjustable. Also, the SLP Bilsteins are $410 for the set (linked to above) while Koni's start around $840 or so. http://www.stranoparts.com/partdetai...D=20&ModelID=7
That's a far cry from $800 and $1000!
