UMI LCA and PHB???
Thanks for the interest in UMI products, I will be glad to help you.
For the aftermarket rear end- If you install a Strang S60 a set of non-adjustable control arms will be fine but we would recommend an adjustable panhard bar. If you go with a Moser 9" we highly recommend adjustable lower control arms and panhard bar to center the rear under the car. From the installs we have done and customer feedback we have found the 9" never sits centered under the car and adjusting it is a must.
If the car is exposed to the street quite a bit I would recommend at least one end having poly bushings or Roto-Joints.
If you need any other help choosing items let me know and I am glad to help.
Thank you!
Ryan
If the car is also a street car here is another control arm to look at- www.umiperformance.com/2039 These are also on car adjustable and feature a combination of poly bushings and Roto-Joints making them very street friendly.
Again let me know if you have additional questions. Thanks!
Ryan
Ryan
My car is 70% street car and 30% track use (mostly 1/4 mile). I can see my car getting deep in the 10's so I will go ahead and get chromoly LCA's.
Ryan
Hmmm so are you saying if not in the 10's class .....It won't benefit that much from the chromoly control arms and panhard rod?
What would the weight saving be from mild steal to chromoly for the two items?
Hope this helps!
Ryan
Hope this helps!
Ryan
I made a custom order to have a set made ...Chromoly control arms and panhard rod w/ roto joints with Jerry .. I wish I would have known this then.
I will call tomorrow to make sure you don't make the items .
I'm still going to buy my items from UMI just not the custom order.
Thank you for the help Ryan.
