Spindle Movement?
Old Nov 27, 2010 | 08:12 PM
Marc3.4V6's Avatar
Default Spindle Movement?
When changing rotors I was breaking the bolts loose for the caliper on the pass side and immediately noticed the spindle twist a little back and forth. Pretty sure the other side didn't do that. What does this mean?
Old Nov 27, 2010 | 08:16 PM
mitchntx's Avatar
Need to isolate the movement.
Did the hub move? change the hubs.
Did the knuckle walk around? Looking at ball joints.
Did the knuckle rotate? Might be a tie rod.
