How would YOU approach making a road race T/A?
I've got a bone-stock '02 T/A with an M6. My goal with this car is the corners.. auto-X 'n the like. I'm concerned with making it handle in the bends as well as a T/A possibly could more so than classes and whatnot in the SCCA.
I don't have a big budget initially so I ask you what brands of parts you'd use and in what order do you imagine you'd purchase them? Considering car is all stock.
That **** cracked me up.
Seriously OP, if you are wanting to setup an F body for cornering I would talk to Strano. Yes I said it, it needed to be said.
There are a lot of sponsors on here that will sell you parts in a heartbeat but I haven't seen anyone besides Sam that has the know how on how to use those parts and explain why/how they work.
I bet by the time I wake up in the morning there will be several posts by sponsors saying, "Hey buy this!" Which I understand is their job.
Then:
Get a performance oriented alignment with a little negative camber.
Talk to Strano, he also sells everything listed below
Koni SA's
Strano sway bars w/adj rear bar
Weld in SFC
Strano lowering springs & UMI ADJ. PHB (w/roto-joints or rod-ends)
UMI LCA's (w/dual roto-joints)
Brake rotors(Racing Brake or ATE) & pads(Hawk), brake fluid (ATE Super Blue)
Once you've got used to all of that, and still want more consider a Fays2 Watts link.
Today, it might not matter. Tomorrow ... you never know.
1. Learning to drive, as stated earlier, is the biggest bang for the buck in getting your lap times down. Its humbling to realize just how many really bad habits you learn while simply street driving.
2. Make the car safe. Flush the brake system and go with a quality brake fluid, pads and rotor combination.
3. Make the car comfortable. Not having to fidget or fight to stay in the seat will allow you to concentrate on #1.
4. Have fun. When you show up, the worst thing you can do is think you are Joe Stud. You won't get a lot of on-track cooperation nor off-track help. Egos have no place at the track. Egos are for the internet.
The title asks "How would YOU approach" ...
After YEARS of HPDE and AX, I decided the next step was Wheel to Wheel racing. It's not as much about low lap times as it is a chess game with the other drivers.
So, I stripped my TA to the tub. If it didn't make it stop, go or turn, it was removed. Weight is the enemy.
Suspension-wise, I went back with a known platform as I had learned from my years of DE-ing.
Five years later, I'm still tweaking with sway bar combinations, spring ratio combinations, shock combinations, tire pressures, etc, etc, etc. Keep meticulous notes and be very descriptive in making the notes. These nuggets of information are invaluable in being able to make an educated guess on how changes will affect the car's handling.
Note that road racing and autocrossing are two different types of driving events.
I'd recommend figuring out what type of event you want to race in and what class. Then work on building around that class.
LS1TECH Sponsor
I can help him out, regardless of what path he chooses. To truly road race one of these his best bet will be to run NASA.
Many folks confuse road racing with track days, and autocross too. So first, figure out what you think you want to do. Then you'll need to find the rules for it, so you can build a legal car and not waste money on things that won't help and might be illegal for the class you choose. Again, this assumes you want to road-race vs. build a good handling track-day car which would not have rules.
__________________
Good point Sam...
I don't want anyone to dictate what I can or can't put on my car on my budget (if someone else was paying, that's a different story )....so i don't run in any sanctioned classes...I just autox with some local clubs for fun! I get to put on the car whatever the heck I want!
That said....Sam is the man with these things. Personally I suggest Koni shocks...Strano Springs and Sway bars....then UMI everything else
However the BIGGEST and BEST thing you can do to corner well is get a good set of tires on it.
I personally think the best three things would be better pads, dedicated tires, and shocks. Tire and brakes will allow you to go deeper into corners, and faster out of them, shocks will just help keep all that rubber on the ground.
I'm assuming the guy just wants a weekend track car for a HPDE.
I talk quality seat time with instruction bc any Joe schmoe can go to the track and tool around with lots of bad habits and thinking he's a badass all while making his bad habits worse. The use of multiple instructors and ride alongs is very important to developing ones' self as a driver.
Do this first. Then look at what you want to do. Do you want to race wheel to wheel? Do you want to do time trial events? Do you want to keep doing HPDEs? Or do you just wantto do auto-x? Then whatever you decide, look into the rules of what you want (hpde doesn't have "class rules") to do and slowly begin adjusting parts as necessary. Remember though, parts that may work for someone, may not work for you..
