are my ball joints bad?
So Im in the process of replacing bushing and shocks on the car. I used one of the tuning fork ball joint separators on the upper ball joint, and a decent amount of grease came out. Does this mean I messed up my ball joint?
also, the upper one seems very stiff in movement, without the spindle attached. Is this normal or is it f**ked anyway?
And finally, any recommendations for removing the lower a-arm? Im replacing both those bushing with new rubber ones. Should I use one of the clamp style separators? anything I should look for while Im going through this process?
Thanks for the help guys.
if you damaged the rubber boot for the ball joint then i would replace it. Im not sure if you can get just the boot for it or not. Its only a matter of time before all the grease is out of the damaged boot and you have a dry socket.
btw why were you removing the upper BJ to do the lower control arm bushings?
I was also doing shocks. and since the fork I have seems to have a problem getting a bite on the lower ones I disconnected the upper first to remove the shock.
I doesnt look like I tore the boot at all, just squeezed it enough to force grease out. Is it supposed to be really tight? the car has 140K miles on it, I would expect some wear making it move easier. :shrug:
