Is this normal??!!!! (Spring Question)
Old Dec 12, 2010 | 07:29 PM
Fastride500's Avatar
Default Is this normal??!!!! (Spring Question)
I just lowered my 99 TA today, picked up a set of Eibach's front and rear with the fronts alre4ady on the struts. It took all day but it was fun and I wanted to try it on my own. The back was easy after I figured out how to pry the spring out. The front was a pain in the *** due to the T50 star nut under the master cylinder.....
My question is now that it is all done I took some measurements from the ground to the bottom of the wheel well. The back is identical at 26 1/4. The front is 25 7/8 on on the passenger side and 26 1/8 on the driver side. Is that difference normal or should they be measuring the same?
Old Dec 12, 2010 | 09:25 PM
99FormulaM6r's Avatar
The drivers side is usually a little higher to account for the height dropping when the driver is in the vehicle (I don't think aftermarket springs make any difference for this), so I believe it's perfectly normal.
Old Dec 13, 2010 | 03:41 PM
Thanks man!
Old Dec 15, 2010 | 06:15 PM
sneaky7980's Avatar
The last time i did my springs my fronts measured equal but my driver side rear was 3/8" higher.
Quirky damn f bodies!
Old Dec 15, 2010 | 06:31 PM
rabbit320's Avatar
ya ive researched a lot and this is very common, in all springs, could twist them to sit different, but itl look even with you in the car...
