Checking Rear Rotor's?
Old Dec 17, 2010 | 03:15 AM
Bobatsuperior's Avatar
Default Checking Rear Rotor's?
I have a slight pulsation in my car the front roto's are almost new, but they are cheap AZ rotor is there a way to check if it from the front or the back. I know the old petal vs steering wheel and to tell you the truth it feel's like both. and advice would be great.
Oh it a 98 Z28 BTW
Old Dec 19, 2010 | 10:29 PM
anyone?
Old Dec 20, 2010 | 05:02 PM
Wesmanw02's Avatar
You would need a dial indicator with a flexible base attachment and a micrometer.
You can measure rotor runout with the dial indicator to see if its excessive. Then check if the rotor is out of parallel by using the micrometer to measure it at 12 different spots.
Most people would not have these tools though, so you would probably have to pull the rotors off and have a machine shop check them.
Old Dec 21, 2010 | 09:39 PM
sjsingle1's Avatar
your pins may be siezed up........check that
Old Dec 22, 2010 | 03:49 AM
stangtrader's Avatar
A dial indicator is the correct way. As far as peddle vs wheel. Warped front rotors will cause pulsation in both
But really you need to use a dial indicator. Iirc spec is .004
Old Dec 25, 2010 | 04:07 PM
Wesmanw02's Avatar
I wouldn't be satisfied with any more than .002 lateral runout.
As far as parallelism, it shouldn't be any more than .001.
