suspension mods
Old Dec 25, 2010 | 05:59 PM
raysadude's Avatar
Default suspension mods
after christmas shopping i still have some $$ left so i'm thinking about buying some presents for my 02 z28, im thinking about buying this
UMI Performance Non Adj. Panhard Rod & LCA's
http://www.ws6project.com/user_stor/...oducts_id=1636
or this
UMI Performance Dual Adj. Panhard Bar & LCA's
http://www.ws6project.com/user_stor/...oducts_id=1635
since the price difference kind of big, would buying the adjustable one worth the difference?
what else would fit in suspension mods other than
panhard bar
rear LCA's
i'm also thinking about buying torque arm, but not really sure if it's worth it。
any suggestion would be appreciated。
Ray
Old Dec 25, 2010 | 06:26 PM
JD_AMG's Avatar
or this
panhard bar
rear LCA's
Ray
What do you plan to accomplish with these mods? What do you want your car to do better?
Honestly I don't see a point in buying the non adjustable ones.
Old Dec 25, 2010 | 07:10 PM
raysadude's Avatar
it's going to be a street car 80% of the time and will see track maybe once every month so my goal is to have a solid street car that handles well and would do decent at the track.
the problem with it right now is i can't hook from 1st 2nd and 3rd, tires are 275 front and 315 back and they are new all around.
Old Dec 26, 2010 | 11:10 AM
JD_AMG's Avatar
Well don't expect any of those mods to help handling. If you want to improve handling the first thing you need to look into is getting rid of the factory shocks for some sport shocks (like bilstien, KYB AGX or preferably some Konis). Assuming you have decent tires as well.
What kind of power are you making? What kind of tires?
Old Dec 26, 2010 | 01:36 PM
BlkBird2000's Avatar
Are you planning on lowering the car? If not then your stock panhard bard will do fine. If you do plan on lowering the car I suggest this package here:
Still adjustable yet not breaking the bank. You don't need double adjustable.
http://www.byunspeed.com/product_inf...b9f9256f519438
Also when lowering the car you will want LCA relocation brackets to correct the angel of your LCA. These are a must if you want to keep traction! I also recommend getting them in the "bolt in" form incase you blow up your ten bolt and want to get a 9" you can turn around and sell these. You can't sell the "weld in" ones.
Old Dec 26, 2010 | 01:39 PM
Do a lot of research. I bought the first thing I was told to buy and ended up buying a lot of stuff twice. Be smart, have fun!
Old Dec 26, 2010 | 07:21 PM
jebuzws6's Avatar
I suggest going with in car adjustable suspension mods for best performance
Old Dec 28, 2010 | 08:24 AM
raysadude's Avatar
My car is bolt ons only, last time she dyno 330/343 with full exhaust only. Tires are brand new sumitomo 275 front 315 rear
I don't know what she's making now after installing ftp 98mm lid and z06 85mm maf. I figure not much maybe 10rwhp more..
I was thinking that LCA, panhard bar and torque arm, sfc would make my car stiffer, launch and handles better no?
I just don't have any first hand experience and every info that I've is based on what I've read here..any information about what's any of those things do to the car would be appreciate
Old Dec 28, 2010 | 08:26 PM
JD_AMG's Avatar
Hook better? Maybe. Handle better? No, not at all.
The point of adjustable LCA's and PHB is to adjust the axle to center it. A short torque arm may help with traction but will hurt handling and possibly cause axle hop when heavy braking. SFC's are arguable, but more often then not people cannot tell a difference. I have a set of 3 point that are welded on and I noticed no difference at all.
The single best thing you can do to your suspension for handling is getting rid of the inadequate stock shocks for some performance sport shocks as Ive already said. The car will be so much more stable, planted and easy to control, and you will have better balance and feel as well.
Search the suspension forums more and read the stickies:
https://ls1tech.com/forums/suspensio...-tech-faq.html
Old Dec 28, 2010 | 09:08 PM
southernculture's Avatar
the purpose of stiffening the chassis is to allow the shocks to work as the shocks and not let the body absorb so much. I would get the koni's and strano or bmr springs. That helped handling alot. I just installed UMI tq arm, panhard arm lca's and subframe connectors. I will let you know how it feels once I figure my clutch issue out.
Old Dec 28, 2010 | 10:21 PM
raysadude's Avatar
thanks for all the info guys!
