Watts Link
Old Jan 22, 2011 | 12:03 AM
gooseit1983's Avatar
listen to sam he sold one to my father in law for his t/a and driving his 02 to my 00 one with a watts link to one with a pan hard bar is night and day but if you order one make sure you talk to the right people. you will sometimes run into rear swaybar fitment with with a watts link. but it is the best feeling and tightness in the rear. if you are planning to push your car to its limits watts link is the way to go!!!!
Old Jan 22, 2011 | 10:18 AM
YellowToy/A's Avatar
Anybody know how much for the MWC watts????
Old Jan 22, 2011 | 01:21 PM
3.8to6.0's Avatar
I'm also interested in the MWC unit.
Old Jan 22, 2011 | 03:16 PM
TransWS6Am's Avatar
X3 im about to order my MWC 9" within the next few weeks, I'm definitely thinking about a watts link after reading up on them.
Old Jan 22, 2011 | 04:26 PM
69TA's Avatar
Originally Posted by ssvert99
our watts link will clear dual 3 inch pipes and is available for universal 3 inch axle tube rears as well as our fabricated 9 inch with the backbrace. it is a direct bolt-in part and is manufactured from chromemoly steel in a lightweight design and fully adjustable. we have them on several street/strip and autocross type cars with great success.
when are you going to do a group purchase
for the MWC 9" and watts link?
Old Jan 23, 2011 | 11:35 AM
I ask Eric.
The watts link setup is 525.00 plus freight with the purchase of a rearend. If your rearend currently has a backbrace on it then you will have to weld on the mount tubes that attach to the housing. the rest of it is bolt-on to the car. the Watts are built to order but we can ship one out in a matter of a a few days.
Old Jan 23, 2011 | 11:59 AM
TransWS6Am's Avatar
thanks bro
Old Jan 23, 2011 | 11:30 PM
libertyforall1776's Avatar
Pictures here:
https://ls1tech.com/forums/gears-axl...over-axle.html
Originally Posted by YellowToy/A
I ask Eric.
Old Jan 24, 2011 | 07:07 AM
TransWS6Am's Avatar
thanks liberty, looks like it leaves plenty of room for true duals.
Old Jan 25, 2011 | 02:22 PM
So I emailed Jim Fay of Fays2 Suspension to see if the Kooks true 3" duals exhaust works with his Watt's Link, but he said: "I can't be sure. Sam Strano would know better than me."
Sam, any insight here? ;-)
Old Jan 25, 2011 | 02:42 PM
99Bluz28's Avatar
Here's my car:
FYI, the Kooks TD's requires the use of a PHB relocation kit to fit, so that's a sign it probably won't fit without fitment issues. The Fays2 does have a little more room, but most of that is in width, not height.
Old Jan 25, 2011 | 02:50 PM
  #32
ssam98's Avatar
this is art what buety. when making this you have love what you do.
Old Jan 25, 2011 | 03:23 PM
  #33
Lightbulb
Thanks for the pic -- that helps. If you get a chance, see if you can do a little measurement in that area where the pipes would pass through for a swag-fit...
You're right about the PHB Relo-kit -- Kooks should work with Fays2/Strano and engineer a Watts Link solution too, if it won't work as-is. The Kooks true-duals is pretty tempting...
Originally Posted by 99Bluz28
Here's my car:
Old Jan 25, 2011 | 03:30 PM
  #34
ssam98's Avatar
Is this a 10 bolt or 12 bolt.
Old Jan 25, 2011 | 04:31 PM
  #35
Sam Strano's Avatar
LS1TECH Sponsor
I can't say.... the fact is there is room for 1 3" pipe over it, but it's tight on the downturn side... width wise there is plenty of room. So it's just a matter of how the Kooks is bent to run downhill. The Watts link frame does sit about 1" further back at that location (under the pipe) than the stock PHB brace.
__________________
Old Jan 25, 2011 | 05:28 PM
  #36
Lightbulb
I phoned Kooks, and their test fit car Trans Am was apparently that of their Production Manager -- I have a vmail into him to ask about a Fays2 Watts Link solution. Since it is Kooks Custom Headers, I have to imagine they can create a solution if possible without having to modify the Watt's Link itself... It looks like they have only tested with the PHB relocation kit from BMR thus far, since that was what was on the test car...
Old Jan 25, 2011 | 06:13 PM
  #37
99Bluz28's Avatar
w/measurements:
Old Jan 25, 2011 | 10:53 PM
  #38
99Bluz28's Avatar
Factory 10 bolt.
Old Jan 26, 2011 | 12:21 AM
  #39
Smile
Nice -- can you fit a pair of 3 in. tubes through there? Got some spare cardboard tubes laying around? ;-) May not be exactly like Kooks layout, but it would be a guide...
w/measurements:
Old Jan 26, 2011 | 09:09 AM
  #40
z28bryan's Avatar
If your just driving around on the street (not doing any racing) and you have to have the Kooks TD's... just stick with a PHB
