suspension help
thankyou
02sslayer
thankyou
02sslayer
Are you going to be more concerned with drag strip performance and streetability or handling and streetability?
For drag only purposes you want a very tall, very soft spring set--but that sucks for handling and looks both. Seems you want some compromise, and I'm guessing wouldn't mind it if the car was better to drive too, right? That's where the combination of springs and shocks matters... The best springs in the world won't work well on lousy shocks.
For shocks, I do think Koni and Bilstein are your two best choices. I carry both (as well as KYB AGX and Tokico too).
I'd be happy to discuss what you are after with you and make some recommendations... Just give me a ring at the number below.
You can always put a threaded sleeve over the OEM or OEM type shock and pick any 2.5ID spring and any rate and length you want. Set ride hieght w/ the threaded sleeve. You could even pick an OEM rate and set the ride hieght you want and not see any difference in ride over OEM.
I use a 7" x 2" threaded sleeve like this:
Then pick one of these 10" spring in the rate you want.:
I have run similar a set-up for 6 years on a 4th gen CMC road racecar w/ no isuues and w/ way more spring rate than you will need.
BMR front/ rear sway bars
BMR springs ( will lower your stance.. not slam your car)
BMR lower rear lower control arms/ panhard bar
Koni adjustable shocks..
This is a similar set up that I have under mine, the car launches great! no wheel hop! and rides just a good off the track.. hope that worked to answer your question
I'm looking for stance & 60ft off the line on the street? Anyone else care to give me some info before I make a costly mistake.
+1 For BMR!! I have them on my car, and love how my car sits now with the new springs. Look at all the latest and recent builds in GMHTP, all those cars are running BMR products.
