What troque arm works with TSP true duals?
The title pretty much says it all. Here is what I have to work with and my obsticales I need to get around. What part do I need to clear Texas Speed Rumbler X True Duals (http://www.texas-speed.com/shop/cate...56&sortby=name) or do I need any??? Plan on also getting Texas Speed Long Tube LS1 Headers ( http://www.texas-speed.com/shop/item...d=899&catid=45 )
This is what I have now to work with
-I have a 9" Moser
-UMI double adjustable panhard bar: link is my part
http://www.umiperformance.com/catalo...u8gvmj5p45rim0
-UMI adjustable torque arm that mounts to the cross member: link is my part
Thanks for the help!!
-I have a 9" Moser
Hello,
Your factory torque arm will clear, so if I read your question correctly the answer is no.. you do not need it to clear. However if you are definitely looking for a torque arm that clears we did design our set up around the TSP duals. Our part #2205 was designed to work with the TSP duals and actually offer better clearance than the factory offer while allowing you to tuck the system up another 1" higher. Below is a link to show this item installed with a set of TSP duals, we just did this installation not too long ago.
Please take a look and let me know if I could be any more assistance.
http://www.umiperformance.com/catalo...o/02cam3-b.jpg
Thanks!
Ryan
Thanks!
Ryan
