HELP need install cost quotes
Old Feb 10, 2004 | 08:53 PM
Jpr5690's Avatar
Default HELP need install cost quotes
ok basically im about to get a whole bunch of stuff installed and i need to know a fair price range to look for to know weather im gettin ripped or not.... the stuff in getting installed is:
randome tech TQ arm
BMR lcas and bolt in relocation brrackets
slp bolt in sfcs
spon front and rear swaybars
belstein shocks
T\A rear end girdle with carrier stud kit
bmr dsl\tunnel brace
lg panhard rod
also i have no clue what the carrier stud kit actually does so chime in on that if ya can answer that one
i thin thats all of it but im shoting to get it done like 2 weeks so i need to know whats a fair install rate for all this stuff
thanks,
john
Old Feb 11, 2004 | 10:08 PM
Jpr5690's Avatar
god dam no one can hepl on this one ...common!
ok ill start i know it wont be over a thousand and im thinking about 500 ???
Old Feb 12, 2004 | 12:19 AM
greekss's Avatar
y dont u do it urself.....most of it is pretty easy
Old Feb 12, 2004 | 03:45 PM
Jpr5690's Avatar
tools, knoledge, time....
Old Feb 14, 2004 | 02:26 AM
Mike01Hawk's Avatar
Man.. do it yourself!!! I'm a total mechanic noob... but with sites like this, I made a fun/enjoyable weekend out of many of my suspension installs.
Tools...
2.5 ton jack w/ stand combo - $25 @ Sears
Common tool set, under $80 @ Sears
Torque wrench(s) ~ $70ish for the click style
From the list you posted... I've done everything except TQ Arm and Rear End Girdle.... and I would have definately kicked myself in the butt if I had paid someone else to do the install. Even the Shock install was pretty easy and straight forward after I figured how to work the dang spring compressors.
Old Feb 14, 2004 | 12:21 PM
jimmyblue's Avatar
Moderator
It took me 8 hours (including breaks and lunch)
to install LCAs, relo brackets, springs, shocks,
Panhard on the rear of my car, and the only
power tool needed was the Dremel for cutting
the brake line bracket strap welds. Two jackstands
and a floor jack, metric deep sockets and open-
end wrenches are needed. The lower shock nut
and the TA rear nuts are bigger than you will
likely get in the usual socket set; I already had
some deep impact sockets that covered that
though.
Look at it this way... you can pay the man, or
you can sweat a little and earn yourself a better
tool collection.
If you found a place that only charged $50/hr
shop rates I think you'd still be into the $400
range for all this and since it's all bolt-ons, it
hardly seems like you'd be getting anything
special applied for that dough. The only thing
you might want to farm out is the front shocks/
springs and if you roll up with the assembly in
your trunk you should be able to get a tire place
to do the press work for $25 a side if it's a slow
day.
Old Feb 15, 2004 | 05:17 PM
locosteelersfan's Avatar
Go to www.installuniversity.com
They can give you install times that
you can estimate costs by multiplying
by labor rate 45-65 bucks/hr.
Or just call a shop
