panhard bar adj or non?
If you are going to run large wheels/tires it will be necessary, but if you're going to run stock tire sizes, the only time it helps is when aligning the car so it doesn't "crab-walk" down the road. My rear end wasn't perfectly centered when it had a stock panhard length, so lowering it only made it worse until I got the adjustable panhard.
LS1Tech Premium Sponsor
Definitely spend the extra couple bucks and get the adjustable just so you will never have to worry about buying another panhard bar agian. Even if you are not lowering the car you will need an adjustable panhard if you are going to put wider wheels on th rear of the car.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
