poly bushings
Polyurethane Bushings
Chassis Engineering - Herb Adams, Pages 22 through 24
Quote from Global West Suspension:
"Polyurethane bushings used on both ends of the control arm. This type of a control arm is best used for drag racing. The bushings however, limit the rear end from articulating. Many drag cars can get away with this because of the way the car is set up. If this type of arm is used on the street or road race applications the rear suspension will be placed in bind when the car goes over bumps and around corners. This is because the control arm bushings will not allow the rear end to have proper movement."
Global West
Global West
Would a rod-end/rod end or rod-end/poly be a better alternative? If which would be the better choice for a Street/Strip car that occasionally finds its way into a canyon cruise?
I have had poly bushings on both sides of my LCAs for 3 years and have never had a problem.
I have heard that heims squeak horribly after a couple thousand miles and that the rotor joints require constant adjustment to keep from rattling or clunking.
I just order a set of adjustable poly ended LCAs from UMI and I know I will be happy with them like I was with the last set, only reason I switched is my old ones weren't adjustable
The poly bushings won't limit anything or bind as long as you keep them greased regularly, ubber is softer and more forgiving than poly which allows for some cushion and a bit of movement to be had.
After looking at all the bushings on my z28 the other day, I can't freakin wait to install my aftermarket poly stuff. They are all so worn out it's going to be a world of difference.
Grease only helps reduce friction, it does nothing to eliminate resistance when the part has to move in a direction other than x axis (rotation).
Herb Adams is an engineer, with more than 50 years experience. He worked on the original WS6 handling package for Pontiac, has his own company, built numerous race cars, and has written numerous books on automotive engineering.
If you really want free movement, in a pure rotation application with no deflection, then use del-alum.
Otherwise a ball bearing type joint will give you pure rotation and articulation.
As a bushing material, the only thing poly's success proves is that marketing works. It's fine for static parts, but not for movement. I digress
Rubber is softer and more forgiving, yes, but importantly it allows the parts to fully articulate, hence why most auto-x people (or even for those people who just want a car that works on the street) use rubber for the front and rear suspension UNLESS they use something like a rod-end or the like. The problem with rod-ends and similar products is that they seem to require more attention for maintanence and don't have the same street manners as rubber....as well as being more $$$$.
LS1Tech Premium Sponsor
Like everyone said the poly-urethane bushings don't articulate nearly as well as a spherical bearings/rod ends. Both poly-urethane and sperical bearings/rod ends have there place it just really depends on what you are doing with the car. If you are just daily driving the car and want something that is going to be a noticable upgrade over stock the poly-urethane bushings are great and will work well for you. If you are looking to really push the car and do alot of cornering or drag race a car that has a lot of power then I would really start looking the suspension parts with the spherical bearings/rod ends.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
