Bilstein shocks
thanks...
also looking for some comments on ppl who've had Bilstein's...
I have used Bils' on all sorts of cars and trucks for years. I think I had maybe two that gave out and needed a warranty claim done. They are OEM on a whole bunch of high end vehicles out there.
They are much better than worn out stockers that's a given. Buy a set and don't look back.
)A few other things:
-You don't really need adjustable LCA's because you're lowering, but that's your call. If you're upgrading them as it is, you might as well get the adjustable pieces.
-Relocation brackets may or may not be necessary. If you don't experience traction problems without them, you don't really need to have them....if you move the rear side of the LCA down too far you can end up with understeer issues also....best angle of the LCA's for a street car is with the LCA's parallel to the ground.
-I would recommend a double adjustable piece for the PHB. By double adjustable, I mean an on-car adjustable piece, not that there's an adjuster on each end (I got this confused a while back, lol). It just makes adjusting easier, but is not necessary by any means....once they're on the car they don't do anything differently!
I dont really want to lower and i wanted LCA's and relocate brackets for once again, suspension upgrade, thats really all. and I need to do something because my T/A spins new rubber like their on fire.
so basically i'm buying for suspension upgrades. after your post, i'm confused on what to upgrade now.
As for springs, if u don't want to lower I'd just stick with the stock springs, they're actually pretty good. The shocks and sways (UMI's are very good, as well as Stranos) make the largest handling difference.
Sorry for confusing you! I'm just trying to help and save you some money.
I'd also definitely call Sam Strano....he's a great guy to buy from and he's great with recommendations!
BTW, if you call Sam up I believe the SLP Bilsteins are a nice amount cheaper than the HD's, and they're almost identical now.
If it matters, she has about 100k miles on the clock, and I have 59k. 15k miles on the bilsteins.
Not bad for about 500 dollars worth of parts IMO. Would do it again.
