ABS Delete Kit?
Old Feb 5, 2011 | 11:03 AM
2000silvrx81's Avatar
Default ABS Delete Kit?
My big and littles are making my ABS do crazy things, who makes a delete kit?
Old Feb 5, 2011 | 11:05 AM
skeeter99's Avatar
SJM I believe is who everyone uses there a sponsor
Old Feb 5, 2011 | 01:57 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Burkhart Chassis also has a delete kit
Old Feb 5, 2011 | 11:54 PM
hiltsy855's Avatar
You can make your own too. Get some brass T's and inverted flare adapters and a Wilwood proportioning valve. Use standard 1/4" & 3/16" brake line from a parts store. The 1/4" is for the rear (front port on the master cylinder) and 3/16" is for the front.
Old Feb 6, 2011 | 12:24 AM
skeeter99's Avatar
i have been wanting to this as well but where do u buy a good double flair tool i have heard horror stories bout leaking lines and and the tool just not working and where would u get a wilwood valve at by its self i know the kit comes with all this stuff
Old Feb 6, 2011 | 02:41 AM
hiltsy855's Avatar
Flaring tool:
http://www.summitracing.com/parts/OTC-4503/
Proportioning Valve:
http://www.summitracing.com/parts/GLS-DB-99/
Harbor Freight has a bender for small tubing:
http://www.harborfreight.com/1-8-eig...der-94571.html
Old Feb 6, 2011 | 02:44 AM
hiltsy855's Avatar
The key to making double-flare line that don't leak is to make sure you cut the tube clean and square. Use a tube cutter, not a hack saw.
Old Feb 7, 2011 | 11:44 PM
hiltsy855's Avatar
Old Feb 8, 2011 | 05:25 PM
dutinsss's Avatar
i bought the sjm kit and by the time i was done i ended up running my own brake lines anyway. and the way i did mine looks even cleaner than sjm's kit. i would just get the parts seperatly if i could go back and do it again. even the double flare tool that came with the kit didn't work. the lines kept slipping out of it so i rented one from o'reillys that worked awsome. good looking kit and customer service, but i definately wouldn't recommend it over just doing it yourself.
Old Feb 8, 2011 | 09:32 PM
hiltsy855's Avatar
^^^ Agreed.
Old Feb 9, 2011 | 09:43 PM
dutinsss's Avatar
^^^ Agreed.
i need to take some pictures but i did mine pretty much just like yours except my proportioning valve is where your line lock is and the line lock is where it normally would be with the kit. i just put the rear brake line T right when the single line from my prop. valve gets under the car. i bet if we could fit the line lock and proportioning valve right up next to the master, it'd look really clean.
Old Feb 10, 2011 | 05:15 AM
hiltsy855's Avatar
Ya, I just wanted the prop valve where I could adjust it. I'd like to see some pics of your setup. You probably did it w/o the motor in place? You're right - the super clean install would be to have everything at the master. I had the same problems with the brake line slipping thru the flaring tool clamp.
Old Feb 10, 2011 | 02:43 PM
SJMMFGINC's Avatar
If you guys want to form your own lines setting the components in alternative locations, we can offer the kit as NON formed with the supplies that you'll need. If you piece purchased what you need, there will be little to now savings.
The base kit which would include all the fittings and lines needed and INCLUDES the adjustable wilwood valve is 139.99. If you want the additional line lock kit option, you'd add 40.00.
Installing a kit as shown above would be difficult with the engine in place.
We do offer the wilwood adjustable valve by itself as well.
Obviously, the preconfigured preformed kit is the easiest way to convert the car.
Old Feb 10, 2011 | 09:04 PM
dutinsss's Avatar
i'll try to get some pics up this weekend but i did mine with the motor in the car. it was a pain but do-able. the hardest part was definately flaring the two factory front lines that go into the T.
Old Feb 11, 2011 | 10:03 AM
9t8z28's Avatar
I have the SJM delete kit. It worked great and looks very clean. Yeah, I had leaks that are fixed now, but it was because of my flaring tool, not their product.
