K-member ride height???????
and since i'm on the subject of suspension, would adjustable lca's be better to buy than relocation brackets?, isnt that the whole point of the relo's is to get the rear end angle correct but if it can be done w/ adj. lca's that'd be better than stockers anyway.............
Actually, I had the opposite happen. My car is about a 1"-.5" lower in the front after k-member install.
I would not mess with adjustable lower LCA's unless your having a chassis shop setup the suspension. Just go with lower control arm brackets and standard LCA's.
damn, too bad about the ride height, did you notice any big differences w/ the new k-member?
oh and I've set up rear end link suspension and traction action bars in the past, I have all the degree's that need to be measured and set up on the rear if I get the adj. lca's
