Konis, first impression after install
Sam walked me through a few crucial steps in making sure these were installed right.
The ride is so much better even with the rears adjusted to full soft. I tried going 2 levels up from full soft and it is a bit more jarring than what I'm used to. I'm still on stock springs, I wanted to try it first before committing to the Strano lowering springs later on.
Overall I couldn't really tell the difference initially going in a straight line but once I turned the car, I was amazed at how much control I felt I had than before. Just point the steering wheel in any direction and the car just goes without any hesitation. Every thing just feels tight and solid, the subframes really help to emphasize these shocks.
Going over rough roads, I don't really notice a dramatic feel for more comfort per say...even on full soft for the rears, but the car definitely handles better and feels glued to the road hugging every dip and incline.
Going over speed bumps, the car doesn't bounce and twist like an old mattress anymore, it's just firm and solid.
So the current setup that I like right now are 3 full sweeps up from full soft on the Front Shocks and full soft on the rears so the car squats a little bit more on accelerating. A bit more comfy too. I tried a couple levels up from full soft on the rear and wasn't too fond of them initially for putting around town.
Expensive shocks! but it does feel like a whole new car as cliche' as that sounds
I'm happy I finally got them over a cam package. I can only imagine how crappy my ride would have been with extra power on the stock shocks. Last edited by jthunderz28; Feb 13, 2011 at 01:46 AM.
Thanks man.
Even my unsuspecting girlfriend felt the difference when I took her on a little cruise in the hills before our Valentines dinner,lol. I was surprised she noticed, hecc she didn't even notice when I went from stock catback to the GMMG until I told her. lol.
It would have been nice to go with the cam and get more power and a nice sound, but I was getting tired of cruising in what felt like an old mattress. In time the cam will come, but this was a mod that should be done by all, even if you go with Billsteins...just any quality piece over the stock shocks. Koni's for sure if you got the cash.
Just curious, I've been looking into them as a possibility in the future, if nothing else as a jacking point.
Put it this way. The subframes were one of the first mods I did. I had the UMI Boxed weld in 3 points done. The car instantly felt better when I was going around long sweeping turns at a steeper angle. It felt as one piece or a lot closer to that than before.
After months I started noticing that everything suspension wise felt as if it was being worn. I attributed this to the logic that the subframes tightened everything up so they had put more pressure on all of the other components on the car from shocks, to the stock control arms.
The subframes helped to emphasize these shocks because the car is tighter and instead of dissipating a lot of the energy through other areas on the frame it just feels like it sends a lot of concentrated energy right to the shocks. Ridding the old mattress feel.
I can't say they emphasize the shocks "more" because I had the subframes on before the Konis, but I know for a fact that they will send a lot more concentrated energy right to the shock. Hence emphasizing them.
I know it will improve the feel but I can't say by how much personally because I went subframes first.
Either way it's a good thing to do to our cars just from the standpoint that it WILL help to transfer energy better to the wheels and ultimately isn't that what you want? Unless you had other mods in mind and this wasn't a top priority. Also helps eliminate rattles which is nice if it's your daily driver.
If the funds allow, money won't be wasted if you get em.
But to each their own as they say.
Like the OP, I settled on three sweeps from full soft up front and full soft in back. They're quick on rebound and great for handling, but IMO, Konis just don't dampen the impact harshness that SFC's transmit as well as Bilsteins.
I've often thought about cutting off my SFC's, but they're good for launching at the track, and great for jacking.
There are always tradeoffs. The Bilsteins may be better designed better for impact harshness with Subframes, but I'm sure the Konis make the car handle a lot better and are more versatile as far as adjusting goes.
I think some nice tires would help minimize some impact harshness as well.
I just ordered the Continental Extreme Contact DW tires, and I can't wait to put them on in tandem with my Konis.
