Which drive shaft safety loop do i get?
I dont know which drive shaft safety loop to get because i heard that my true dual exhaust would get in the way does anyone know who makes one for a true dual setup
LS1Tech Premium Sponsor
Honestly with true dual it is real hit or miss to which ones work and which ones don't. I have quite a few customers that have used our BMR driveshaft loop and built the exhaust to work with it, but I am not sure you will find an off the shelf loop that will work.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
who makes a torque arm with a front and rear drive shaft loop besides spohn? does any vendor make front and rear driveshaft loops that work with other manufacturers torque arms?
also, what should i get as a mount? a poly busing or a roto joint? it is primarily a street car.
sorry to hijack but thanks in advance for the responses.
thanks for all of advice. i ended up purchasing the universal drive shaft safety loop from summit then had a shop customize that one and it worked out pretty well
