LG Style Front Control Arms?
Not really sure why a street car would need these. They really would be for people who want to run a -2.0 or greater camber (road course, autox, etc.)... Camber like that on a street car just means your local tire shop will love you.
So this time around I hope all of the UMI pieces will get my alignment right as well as save some weight and tighten everything back up, and that is worth it to me
Deep down, I don't think most of what we all come here for is about need; it's about are wants!
Sharper turn-in, lighter weight, and it looks a lot better then the factory lower A-arms, is reason enough for most to buy them.
Yeah, but some of these cars are tweaked from years of abuse. It took the alignment shop (a GM dealership) 6 hours to get my car back to factory specs. If I would have had my k member and arms it would have been a fraction of that time. And none of the bolts were seized, it just didn't want to go into where it was suppose to go. And then its still not right IMO.
Need... You know as well as I do that it's all about Want!
But either way I'll be ordering a set of chromo a-arms and k member from UMI in a couple weeks, unless these new arms strike my interest, but I think I'll stick with the tubular arms. They just look badass IMO, especially when they are there instead of some rusty *** stock arms
Subscribing. Been runnning BMR's upper and lower's for almost 8 yrs w/ rod ends and not a peep. This setup has seen many laps at the Nurburgring, Hockenheim, the autobahn and plenty a country back road in Germany...and if anyone has ever been there, they have some roads that would kill factory suspensions if taken incorrectly. Don't know why people shy away from rod ends, my entire car runs spherical bushings...can't imagine anything less and most who ride in the car never know the wiser.
W/ that said, I'd be on for a set of these A-arms if produce. Been wanting the LG style arms ever since they came out and was too cheap at the time to get them when the were in production.
Really. Car is dead quiet and no rattles when hitting bumps etc. I know they're supposed to be changed every 2-3 yrs but I'm still on the original ones. Keep em' cleaned and lubed well w/ liquid wrench.
#34
It all depends on the link quality/design, how clean and lubricated you can keep them, as well as the manufacturer. I've had the best luck with the QA1 XM heims, they are chrome moly and teflon lined. They very rarely make noise, the ride is a little more harsh from direct vibrational translation into the body but that just comes with the territory
I would also recommend the UMI roto-joint, looks very promising!
#36
The iso links would be ideal then for the IRS trailing arm-body connection as well as the front link of the front lower control arm, however I would still run a the roto-joint for the rear link of the front lower control arm in your case. This would give you improved ride quality as well as better longevity out of the joints, this would seem to me the best compromise out of both worlds in your case.
I can't wait to see what UMI has for us though!
#38
Here is one proto-type picture I have so far. I will be able to get a few pictures shortly of a completed, coated and assembled arm but this gives you an idea of the design.
Thank you,
Ryan
Thank you,
Ryan
