Brake upgrade ????
stock with rear drums. I just bought some c6 Z06 rims for it and want to
ditch the drums for a much better disc setup. My question is - What is
needed to do this conversion. I have seen several SS/TA partouts in the
classified section that I would be able to get a set from, I'm just
curious to what is needed from either to make them work(apart from the
given like calipers,rotors,new lines). Thanks for ANY information.
http://www.wilwood.com/BrakeKits/Bra...20Brake%20Rear
I can get the low-profile ones cheaper @ summit ($767.38)
Just wondering if anyone here is running a set or have had past experiences with wilwood...
thanks for any info
Your best bet IMO would be to get a whole rear out of a V8 car with a 3 channel ABS system (no-TCS) and just toss it in. You will get a posi unit and the disc's that you want.
